Oil & Fuel 24 hp onan oil pressure
   / 24 hp onan oil pressure #1
Wlighty23
Audubon, mn
Mustang 330
My 24 hp Onan has good oil pressure at high rpm's. at idle the pressure drops to zero and the gauge will occasionally flicker. Oil pressure switch? Gauge? Any help will be appreciated.
   / 24 hp onan oil pressure #2
When I see that in the automotive world,or large engine world,I put a pressure gauge on it and check it. If you are using really lightweight oil,it can cause this.
I had an old worn out 6 cyl. Ford Fairmont that the light would flicker on at idle. Because I used it to get to work every day(50 mi. round trip),and it didn't burn any oil, I just switched to 15W40 for diesels and ran until a deer bent its frame(unibody).
So if you're using some 5W-30,you might go to 10W-30,but I'd check the true pressure first. don-ohio :)^)
Thanks Don. I have a dumb question. Would this motor have the low oil pressure shut down? This motor is a transplant in my skidsteer. It runs great no knocking or smoke. I would think it would have started knocking or something with no oil pressure. Thanks for any ideas. Wlighty
   / 24 hp onan oil pressure #5
If you are using a Fram oil filter, change to Napa Gold.
Move to straight 40W oil.
I live in MN. Will that be a problem in cold temps? The machine is not in a heated shop.
   / 24 hp onan oil pressure #7
I wont' make that call for you.......and I don't live where temps get to 0.
Your main and rod bearings are worn to the degree that at low RPMs the oil bleeds out and pressure is lost. Multi weight oils are just too thin.
   / 24 hp onan oil pressure #8
The grade of oil may be too light, but not all multigrade oils are to light. A 5w-40 and straight 40w will be the same viscosity at operating temperatures. Only cold temp viscosities are different. Forty years ago multigrade oils would shear out of grade or gum up due to the polymers used, but not so today. Now they offer superior performance over straight weight oils.
I'd check the pressures first with a good gauge.
   / 24 hp onan oil pressure #9
Ditto on the gauge... but try the 15W40 first .....
don't forget about synthetics even wider ranges and better suited to heat variations. could even go higher than 0W-40 .
minimum PSI at idle should be 10 PSI you need 7 PSI for each 1000 RPM to keep bearings lubed properly when hot and running.
Thanks, as soon as it warms up a little I will take a manual pressure check. I think 40 synthetic will be my next oil of choice.
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2022 Bobcat T770 Skidloader (RIDE AND DRIVE) (A50774)
2022 Bobcat T770...
2007 Generac QT06030AVAN 60kVA LP Generator (A50322)
2007 Generac...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
