24hp V twin Briggs running issue
   / 24hp V twin Briggs running issue #1
wildstyle
Terrace, BC
Craftsman YT4000
Hello everyone. First post on here. Recently upgraded from a 2007 LT1000 with the 16.5hp Briggs to a 2012 YS4000 with the 24hp v twin. The tractor has 40 hours on it, I bought it from a widow who hasn't used it much in the last year. I just started to have a misfire you can hear out the exhaust when it is running with no load on it it seems. I put new plugs in it, and it didn't make a different. If I un plug one cylinder and run it it runs smooth with no missing/popping out the exhaust. If I disconnect the opposite cylinder, same it runs fine. If I connect both it goes back to popping out the exhaust. Does this sound like it needs a valve adjustment? Maybe a carb problem?
Thanks!
   / 24hp V twin Briggs running issue #4
Hey Wild,
I was curious if you ever figured out what was wrong and if you discovered a solution. How are things standing ?
John
   / 24hp V twin Briggs running issue #5
That sounds like a valve adjustment to me. It's pretty simple, and if you take the plugs out, you can turn the engine by hand on the top.
2014 FREIGHTLINER CASCADIA MID ROOF SLEEPER (A54607)
2014 FREIGHTLINER...
2008 CHEVROLET C7500 BUCKET TRUCK (A51406)
2008 CHEVROLET...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
2011 GALYEAN 130BBL VACUUM TRAILER (A53843)
2011 GALYEAN...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
