2500 Clutch Rusted to the Flywheel
   / 2500 Clutch Rusted to the Flywheel #1
PROSOUTH
2500 Clutch Rusted to the Flywheel Well it did, I used the tractor a couple of months ago and forgot to apply the clutch pedal latch when I shut it down.
I serviced it this week from front to rear before I ever attempted to start it. Changed ALL fluids and put a set of springs under the seat to replace those worn out rubber bumpers that will shake your teeth.
Got on it to start it and it would not go into gear. I knew then what had happened. I came in and fired up the computer to see what the remedy was and found a post on the Hoye site here that says to let it push against a tree or other larger solid object to break it loose. Well it didn't and believe me I tried.
I went to a friend that runs the local JD shop and asked him. He said to do the exact opposite. Put it in the highest gear and going as fast as you can lock the brakes. Sounds dangerous, but it did work and the first time I did it.
j
   / 2500 Clutch Rusted to the Flywheel #2
Lock the clutch pedal down and start the tractor. Let it run at about 1500rpm for an hour. it does wonders.
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2008 Chevrolet Malibu Sedan (A51694)
2008 Chevrolet...
Loftness Mulching Head (A51573)
Loftness Mulching...
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
24'' Mini Excavator Bucket (A51573)
24'' Mini...
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
