2520 Hydraulic Vibration/Leak
   / 2520 Hydraulic Vibration/Leak #1
JD333
Maine
JD 3320
Hi folks,
I just picked up a 2009 2520 last week with 135 hrs. After the engine is started and runs for about a minute, there is a harmonic vibration that develops in what seems to be the hydraulic system. The inlet portion of o-ring slip joint that mates with the hyd. oil cooler is vibrating excessively with the frequency of the source of whatever is causing this. It has effectively worn the o-ring out in the joint and is now leaking. When I put my hand on the hyd. inlet line to the cooler, I can distinctly feel the vibration is being developed somewhere in that line, but the discharge line of the pump does not seem to share this symptom at all. Has anyone ever seen or heard of this issue or have a possible remedy. Oil levels look good. Engine seems to run fine. Any help greatly appreciated.
Thanks,
Jake
2008 KENWORTH T-300 LUBE TRUCK (A52472)
2008 KENWORTH...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
HYUNDAI 30D-9 STRAIGHT MAST FORKLIFT (A51246)
HYUNDAI 30D-9...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
