2538 Curl cylinder repair kit?
   / 2538 Curl cylinder repair kit? #1
Neversosure
Franklinville,NJ
Mahindra 2538
I noticed my left curl cylinder is leaking a little bit. I called the dealer and they said no repair kit exists? Can this be truly possible? Do I have to buy a new cylinder for $700+???!!!!!
I have a local hydraulic store where I can source the parts after I take it apart, but it puzzled me that they do not carry repair parts like this........
If I was given the wrong info on a kit for this cylinder someone please let me know if there is a rebuild kit from Mahindra.
   / 2538 Curl cylinder repair kit? #2
The repair parts are fairly common. Your local hydraulic shop should have the items laying around. If you really get in a pinch you can figure out who made the loader. It’s an American company.
   / 2538 Curl cylinder repair kit? #3
I had the exact same problem a month ago. Curl cylinder leaking.
Went to a local auto/truck/farm repair place. Guy had the seals in stock. Got it back in 24 hours, and he was busy. $125
Good luck!
   / 2538 Curl cylinder repair kit? #4
Had the same problem, but mine was because I put a good nick in the shaft.
The shop fabbed up a new shaft for me and repaired for about $250.
   / 2538 Curl cylinder repair kit? #5
probably the easiest thing to do is let the hydraulic shop fix it. Probably won't cost much more than the parts.
2014 STEPHENS CRUDE (A50854)
2014 STEPHENS...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
UNUSED AGT QNT50R EXCAVATOR (A51243)
UNUSED AGT QNT50R...
DRUM OF MISC HOSE CLAMPS (A51244)
DRUM OF MISC HOSE...
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
2016 Ford Focus (A50324)
2016 Ford Focus...
