2538 how wide with R4 tires?
   / 2538 how wide with R4 tires? #1
mike35549
Bronze Member
Walker Co. Alabama
Mahindra 2538 with FEL
How wide is the 2538 with R4 tires on it. I know the specs says it is 60" wide but would figure it would be a little wider with R4's. You see these packaged with 5' and 6' implements just trying to figure out which is the better fit 5' or 6' if getting a cutter and box blade etc. seems you would want one as wide or a little wider than your tires.
   / 2538 how wide with R4 tires? #2
I think that info is on the Mahindra website features and specifications pdf and also in your owner's manual. 59.8" (1520mm) with Industrial Tires, (R4).
   / 2538 how wide with R4 tires? #3
6ft mower is a lot of weight bouncing around on the 3point of that size tractor and its a bit under HP for a 6ft... plenty will prolly jump on here sayin oh I run one and does great... but if your going to use it like a shredder is made to mow down youll want a 5ft
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2011 Kubota L3200 (A50120)
2011 Kubota L3200...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2006 Dodge Ram 3500 4x4 Pickup Truck (Diesel), VIN # 3D7LX38C36G220767 (A51572)
2006 Dodge Ram...
