26 HP Kohler pro intermittent engine misfire
   / 26 HP Kohler pro intermittent engine misfire #1
rdreuer
Beaufort, SC
craftsman GDS 6500 with 26HP Kohler Pro; Ariens MaxZoom 60 with 25HP Kohler
I have a Craftsman garden tractor with 26 hp Kohler pro engine that has an intermittent misfire on right cylinder. it seems to happen more when engine is warm. no change in spark plug appearance and replaced with new plugs but no change in problem. When it is occurring I can remove the spark plug wire on right side with no change in engine running, but if pull left wire the engine stops. I believe it could be the coil but wondering if there is an easy way to test. it occurs intermittently but will last for several minutes at a time when it occurs.
   / 26 HP Kohler pro intermittent engine misfire #2
My boys Toro commercial ZTR with a Kawasaki two cyl run chitty when it was warmed up. Found a big nest on top that cyl. Removed same, cleaned motor up... Now runs like a top. Just an idea... pull the shrouds.... usually does not take long. Once you get the shrouds off, and if you have separate coils firing off the ring gear... you can swap them and see if the problem moves.
I had the shroud off and everything looked clean yesterday. will try swapping the coils.
thanks.
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A54865)
2015 Freightliner...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
2023 Ford Explorer SUV (A55758)
2023 Ford Explorer...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A56138)
2012 INTERNATIONAL...
