2600 Wiring Issue
   / 2600 Wiring Issue #1
dkidd
Aiken, SC
Ford 4610
I've had a gas 2600 for awhile now and decided that I wanted to fix all the wiring going to the instrument cluster. When I got it the oil pressure switch was working, but that was about it. I have now clean up all the existing wiring replacing where needed and have it all connected back in accordance with the wiring diagram. Now it appears everything is working. However, the lights work when the tractor is not running, but cut off when cranked up. Any ideas? The hot wire is running from the battery side of the starter solenoid through the ignition switch and to the light switch.
Dave
   / 2600 Wiring Issue
Thanks Rick. Poor wording on my part. The hot wire shares a spade connector on the switch, but the light switch is not powered through the ignition switch. Also, I went out this evening and took another look at it and the light is on when the tractor is running but it is very faint. Bad connection, bad switch?
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2016 KIMB Garbage Truck (A51692)
2016 KIMB Garbage...
2007 Ford F-350 9FT Stakebody Flatbed Truck (A51691)
2007 Ford F-350...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
2004 Honda Accord Sedan (A51694)
2004 Honda Accord...
