2615 hst stuck in reverse gear?
   / 2615 hst stuck in reverse gear? #1
mapp1
South Mississippi
Mahindra 2615 HST w/ FEL
I have a 2005 2615 hst with fel with 177 hours. I was working in the yard a couple of days this week and noticed that any time I pressed the reverse pedal then let off it the tractor still wanted to go backward unless I placed it in neutral or pushed down the forward pedal several times. When I say it kept going backward, I don't mean at full speed but very slowly. I was on level ground so gravity should not have been an issue. Does the pedal need to be adjusted or do I have bigger problems?
   / 2615 hst stuck in reverse gear? #2
There is an adjustment for that under your Rt foot rest.
What is the correct way to adjust the pedal?
   / 2615 hst stuck in reverse gear? #4
On my 2810 there is a spring going in each direction to pull the pedals back
into the neutral position..... I Started to have the same problem and then about a week later one of the springs broke and the pedal went to the floor !!.... I went down to the hardware store and bought two new heavy duty springs the same length and it has worked fine ever since.....
Dave in NH
   / 2615 hst stuck in reverse gear? #5
I have to go to a funeral today, and can't check till tomorrow, as I can't quite remember how to do it. I know if I take a look under the step on one ot the tractors, it will come back to me. I will check tomorrow and post it for you.
Commercial truck Frame with Axle (A59230)
Commercial truck...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
