NorCalMatt
Hi All:
in doing my Spring maintenance on my 2615 HST I came across a couple of issues I could use some help with.
The first is the front end. I drained and refilled with gear oil (I see after researching here that hydraulic fluid may be preferred) and I just can't seem to get enough in there to flow out the fill plugs. The book says it takes 4.4 qts. and I've put in at least 5, and I can't even seem to get more in the fill cap (I'll add a couple of cc's and it will take 30 seconds or so to finally drain down). This happened at the 50 hours service too and I eventually gave up. It seems to be working fine, but I want to make sure I'm not doing damage up there. Has this happened to anyone else? Any thoughts?
The second is a stripped zerc fitting in the Mahindra front end loader. We'd been using the FEL a lot for the past two months, really beating it up, and it looks like a zerc backed out far enough for the bucket to hit it and strip it right out. The next biggest size zerc I've found is a 1/8" pipe thread type, which if course I don't have a tap for. And even if I did, there's not much depth for a tapered tap to cut sufficient number of threads. Any suggestions on how to repair are greatly appreciated!
Thanks, in advance,
Matt
Thanks, in advance,
Matt
