2615HST bogging down
   / 2615HST bogging down #1
vtwinkicker
northwest Catskills,NY
Oliver Super 55, Mahindra 2615HST, Ariens GT 16
Hope someone has some ideas of what to check. Dealer didn't have any suggestions.
My 2615 HST starts and runs in low range. When I try to use medium or high it will bog down and stall. I changed all the filters and fluids recently thinking maybe a clogging filter was restricting flow but that made no difference. Any ideas?
   / 2615HST bogging down #2
A lack of fuel could be gunk in the fuel tank right at the outlet-somewhat common. Rarely it's a collapsed fuel line.
I have a 1538 HST and never use high range. That's a driving down the road only gear. Medium range is just for moving on the property and plowing down hill. Low range for moving piles and doing most work. I don't have anything that runs on the PTO so I don't have any advice on that part. I say all this since even at 38hp I can bog down my machine like you describe if I'm in the wrong gear.
   / 2615HST bogging down #3
Maybe something stupid and simple as a stick underneath jamming the brakes on...?? My 1526 climbs hill pretty good in medium range if I keep the rpm's up around 2000. It's actually a pretty gutty little work horse with only a little over 25hp to work with. Please post what you find for us....!!! :)
A lack of fuel could be gunk in the fuel tank right at the outlet-somewhat common. Rarely it's a collapsed fuel line. I have a 1538 HST and never use high range. That's a driving down the road only gear. Medium range is just for moving on the property and plowing down hill.
That's exactly when I experience the bogging down,trying to get down the road on the property a little quicker. All work is done in low. I should be going up to the property end of the week so I will look into the fuel tank sediment possibility.
Maybe something stupid and simple as a stick underneath jamming the brakes on...??:)
Certainly won't hurt to poke around and rule that out! I could only hope it will be something that simple. :^)
KUBOTA M9000 TRACTOR (A51243)
KUBOTA M9000...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
2006 Ford F450 XL Bucket Truck (A47384)
2006 Ford F450 XL...
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2007 Ford Edge (A50324)
2007 Ford Edge...
