greg_g
Super Member
- Joined
- Dec 18, 2003
- Messages
- 6,126
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
If we have the same manual, presumably you found the transfer case on pg62. If yes, page backward to the diagram on pg54; the creeper box. Generically it's referred to as the mid-connect box, as it could contain either a creeper gear train, or a shuttle shift assembly. Regardless, note that the rear is open. That's where it mates to the tranny, with which it shares gear oil. Given that the creeper is essentially part of the transmission, the transfer case is still the lowest common point. Rotating gear trains create fluid dynamics inside the various cases, which in turn often form currents - in which stuff (like roll pins) ride along. My KM454 had a shuttle in the mid-connect box - rather than a creeper - but the transfer case was nonetheless bolted on directly below. The 1/4" steel bearing that was inadvertently dropped in through the top, made it's way all the way through the tranny, into the shuttle box, and down into the transfer case - where it ultimately did it's damage several months later.
//greg//
//greg//
