I am going to plant aproximately 3 1/2 acres of mandarins this fall on my 5 acre parcel that does have a hill. The remainder of the property contains a house, backyard, frontyard and a lawn. I will be landscaping the backyard soon. I will also maintain the lawn in the backyard I will have. I need to run a rock rake, and a rear mower or flail mower, and spray rig.
Currently, I have removed almost all the trees but have many rocks on my 3.5 plantable acres. I will need to also brush cut prior to lining up my mandarins and putting in irrigation. Then I will need to manage the weeds and the grass/brush as it grows. I also own a Bobcat 863 with a front end loader.
I would like to go with a Kubota tractor. I have looked at the B, L, and L40 series.
I would love to go with a 3940 as many dealers have these as rental returns. However, I run up against quite a few fences on my property and it seems to be quite big for my property.
I have looked at the 3400 but it seems that it might be tough sleeding for a 84" squeeler rear mower with small 9" offset. Looks like the manual says 30 to 50 hp while the brochure says 35 to 50 pto required. However, I would prefer an offset flail mower. The 3400 has no mid pto so no mid mower.
I have alsolooked at the b7800 and would go in that direction if it had enough horsepower and pto. I wonder if I could use the mid mount mower as my 72" mower 4" mow height max on this unit. This would allow me to directly go over anything I want to mow rather than have something to mow that trails me. However, I do have the rocks and the ground will be variable and bumpy with peaks and valleys.
I can get away with not getting a fel and just use front weights as I have the bobcat. However, any hope of have a rear backo is eliminated because I would need the fel as support for the backo. Thuse, It is not worth 7 to 10k for me to bacco.
I want the power but I need the mobility. What should I get?
Thanks, Mark
Thanks, Mark
