3 cyl deisel engine-Perkins
   / 3 cyl deisel engine-Perkins #1
Nat
Platinum Member
Central NC
I know a lot of you here are always building a small tractor of some type and the power plant is always an issue. I have a small 3 cyl Perkins diesel that would make a great small tractor, repower a garden tractor, wood splitter, home generator ect. If anyone is interested e-mail or PM me. Thanks, Nat
   / 3 cyl deisel engine-Perkins #2
Is it an "AD3-152"? If so, you've got one of the most fuel efficient and durable diesel engines ever built. And cheap to rebuild when the time comes. A complete "kit" (EVERYTHING except injector pump) is just over $400. That would be the powerplant that made the Massey Ferguson 135 famous. (Roughly 45 gross hp)
This is a 103-09 Perkins. It is a small 1 litre engine, 23 HP.
The 152 Perkins came standard in a lot if different equipment plus in AC, Massey, Oliver, and Bobcat to name just a few. Thanks, Nat
   / 3 cyl deisel engine-Perkins #4
Does it have radiator, fuel tank and stuff or is it just the engine? What do you want for it if I pick it up?
It is complete with radiator, fuel tank,starter,altenator. everything. It will start up sitting as it is and you can hear it run, then I'll load it on your truck for 700.00. I have the hour meter so you can see the actual hours, if I Remember it's 1700, maybe 1900, can't remember. It has the bell housing and I have the plate that hooked the flywheel to the generator shaft so that hooking it back to something else should be simple. All it needs is a home. Thanks, Nat Angell
   / 3 cyl deisel engine-Perkins #6
hi Nat, how heavy is this unit, will it fit on a 4 x 3 pallet
The engine with the fuel tank, bellhousing, radiator, and base frame is probably 450 lbs, and about 2 x 5 foot. It could go on a 3 x 4 pallet if the baseframe was shortened or removed. It is pretty simple to do with the act torch. HTH, Nat
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
1049 (A50459)
1049 (A50459)
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
