3 phase problem
   / 3 phase problem #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
Just wanted to share a Doh! moment. A friend of mine wanted me to forge him a dagger/knife. He has metal from his dads workshop but its 1'' thick. The blower i currently have on my forge is good enouch for the thin stuff but i need a larger blower for this. So i ordered one, well i thought great its 125 cfm, 120 vac thats what i need. What i didnt read was 3ph. Didnt even see it, but its right there.
So my question is its a 115v 60 hz .6 amp electric motor
whats the cheapest way to go about using it on a standard household current. I was thinking an inverter? any suggestions, besides getting my eyeglass prescripion upgraded. /forums/images/graemlins/laugh.gif
thanks in advance
forgeblast
   / 3 phase problem #2
The info you provided isn't clear to me. Please have a look at it and verify. You said the motor is 3 phase, but also said 120V / 0.6A. If the CFM is correct, I wouldn't suspect a 3 phase motor is needed. I'm missing something..............chim
   / 3 phase problem #3
forgeblast, something also sounds not quite right about this. Most (all?) 3PH stuff I've seen is either 200V, 208-230V, or 460V, (and is there a 600-something volt?), but never 115 volt. It takes just one "leg" from your main panel to get 115 volts (speaking very generally here), so I have to believe that motor is single phase. A picture of the faceplate from that motor would be very interesting to see.
And it is IS 3PH, I wouldn't bother with a converter. They are fairly expensive, and defeat the efficiency that is gained by running a 3PH motor on real 3PH power. Best just to return the motor and get a single phase.
As always - if I'm "all wet", please forgive me. /forums/images/graemlins/smile.gif
John
   / 3 phase problem #4
I get enough heat just from the draft on my wood stove to get near weld heat!! Very bright yellow on 1" round.
Have you tried your trusty shop vac?
   / 3 phase problem #5
if you don't exchange your blower, and really want to try to use 3ph: i'll look around and find the article i have that explains all that stuff: you can us some capacitors to change the phase of one leg or another motor in series, i've seen it done a lot, because used 3ph motors are usually really cheap compared to single phase...
heehaw
   / 3 phase problem #6
If in fact the motor is a 3 phase motor it would be cheaper to replace the motor than to purchase or build a phase converter. Go on line to the Grainger site and try to find a 115 volt motor of the same horse power that will replace the existing motor. If you can not purchase from Grainger take the information to a local supply house and have them get one for you. Or, as someone else wrote, try a shop vac to see if it will do what you need.
Farwell
   / 3 phase problem #7
Hi there:
like others said, 3 phase is 240 vac or 480 vac, not 120 vac. 120 is single phase. now that you have it if it IS a 3 phase then you can buy a Frequency Drive which will run on 220 vac single phase and provide 240 vac 3 phase. redily available but slightly expensive, in the $200 plus range.. for smaller applications.
there are some small fractional HP motors which can be controlled using different hook ups caps & inductors to provide a offset frequency... that said it is not somethign for a novice suer to be albe to setup. best bet is to get standard single phase motor & retor fit or send it back to et the right one.
mark M
   / 3 phase problem #8
Get a variable frequency drive. Should be able to find one pretty cheap on Ebay. This will also also you to control the speed too--very handy.
   / 3 phase problem
I wish i could return it, i made some modifications to the blower before i messed with trying to put a plug on it. So at this point its mine. /forums/images/graemlins/grin.gif The blower i have works fine like i said for small stuff and the noise level is perfect, the shop vac would drive me crazy with all the noise it puts out. I used a vaccum cleaner motor to melt aluminum in college, we did some styrofoam vaporization casting. I have bid on a inverter on ebay and the variable frequency drive looks like a winner too if i dont win the inverter. As for the motor i will write down everthing thats on it when i get home from work. I do know that the power wire coloring that comes off of the blower is UK.
Thanks for all the help,
forgeblast
   / 3 phase problem #10
Mark, I had a 3phase 115v motor on a conveyor where I used to work. I had never heard of such a thing until I saw it. We ran it with an inverter that was 480 primary and 115V 3-phase secondary. It sounds weird but it's out there.
2006 IC PB30500 School Bus (A46683)
2006 IC PB30500...
2015 Ford Explorer AWD SUV (A46684)
2015 Ford Explorer...
2057 (A46502)
2057 (A46502)
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A45336)
2018 Generac...
1491 (A46502)
1491 (A46502)
OMI 27ft. Pasture Harrow (A46502)
OMI 27ft. Pasture...
