3 point and loader will not move unless RPMs are over 2000 but still move slpw
   / 3 point and loader will not move unless RPMs are over 2000 but still move slpw #1
mahindra 2012
corpus christi texas
Mahindra 5010 HST
Recently got my Mahindra 5010 HST tractor back from a friend who relayed to me the bucket and three point system were moving extremely slow and would only work slowly with the tractor at 2000 plus RPM all filters have been changed along with fluid valve under seat I believe is for speed control has been adjusted but males no changes
   / 3 point and loader will not move unless RPMs are over 2000 but still move slpw #2
Have you checked to be sure hyd fluid is at full mark? Have you checked hyd pressure with a gauge?
   / 3 point and loader will not move unless RPMs are over 2000 but still move slpw #3
Also check for pinched lines or hoses.
   / 3 point and loader will not move unless RPMs are over 2000 but still move slpw #4
Fluid levels, filter condition, type fluid for your climate.
Some tractor have a divider/priority valve that supplies the steering first, and if there is excess GPM, the loader will operate.
A flow and pressure test would be appropriate.
You could remove a hose from one of the loader work ports and see if you have good flow at low/high rpms.
Your pump just might not be pumping at specs. If you have a 10 GPM pump at max rpm, then you should flow 10 GPM to the loader and 3pt at max engine rpm.
   / 3 point and loader will not move unless RPMs are over 2000 but still move slpw #5
Is it worse when it is hot? CJ
   / 3 point and loader will not move unless RPMs are over 2000 but still move slpw #6
TractorData.com Mahindra 5010 tractor attachments information
tractordata denotes an optional backhoe for your tractor. if you need to disconnect a couple hoses to attach to backhoe, (when attaching backhoe), and then reconnect hoses back onto tractor, so 3pt hitch starts working again. redo the "quick disconnects", pull the hoses off and simply reconnect them. some times QD's do not set correctly and do not allow proper flow through them.
2010 Chevrolet Tahoe SUV (A55758)
2010 Chevrolet...
2014 VOLVO EC220DL EXCAVATOR (A51406)
2014 VOLVO EC220DL...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A55788)
2015 Ford F-250...
Hydraulic Hose Crimper (A50775)
Hydraulic Hose...
