3 point hitch not working
   / 3 point hitch not working #1
ottawa1979
Shawville
Ford 1910
Hello,
The 3 point hitch on my Massey Ferguson 1080 will not lift. My PTO and multipower work but the arms are stuck in the down position. Anyone have suggestions?
   / 3 point hitch not working #2
Call Harry Ferguson, he sued Massey-Harris for $9million for using his 3-pt hitch mechanism! Not sure how it ended up Massey-Ferguson (but that might be part of it :D) .
Just kidding. Have you checked all the linkages that operate the valves to the lift cylinder? Any pins missing?
Everything seems to be in order, nothing missing. It is worth mentioning as well that I haven't used the hitch in 2 years.
   / 3 point hitch not working #4
Sodo - Actually Harry Ferguson sued Henry Ford for using his Ferguson system (hydraulics) in the Ford 9N. Ferguson merged with Massey-Harris somewhat later.
OP - Stuff happens in storage. You may have a stuck control valve spool.
I think you are right Opti-Mist. I just hooked up my backhoe lines to the remotes and it is working. Is this part serviceable or does it need to be replaced?
   / 3 point hitch not working #6
On my BX24 ( sold it ) no hydraulics worked if I forgot to connect the backhoe loop together.
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
Michigan L-90 Wheel Loader (A52384)
Michigan L-90...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
TEST YOUR BID BUTTON! (A51246)
TEST YOUR BID...
