Tractor Sizing 3 Point Hitch Size - YM1601D
   / 3 Point Hitch Size - YM1601D #1
frankmako
Bronze Member
North Georgia
Ford 4610, Ford 3910 and YM1601D
What size is the 3 point hitch on a YM1601D? Is it a cat 0 or is it a cat 1?
Frank
   / 3 Point Hitch Size - YM1601D #2
I would say cat 1;; all of the ym1500's I've looked at have cat 1 and ym 1600 is bigger.... CAT 1....
   / 3 Point Hitch Size - YM1601D #4
I am assuming it is like/similar to a ym1500.
(I am not an expert on hitches...)
It seems that stardard catagory 1 hitches have a 26" wide spacing on the bottom two points.
However, the ym1500 has a 18" spacing between the two lower points.
This is just an observation -
That raises another quesiton. What are the specs for a catagory 1 hitch?
All of the implements I use, I have built myself. (box blade, moldboard plow, ripper) I copied the hitch spacing off standard cat. 1 implements.
THEY DID NOT FIT!
I assumed that all cat. 1 hitches were standard - this apears to NOT be the case.
   / 3 Point Hitch Size - YM1601D #5
THEY DID NOT FIT!
All cat 1 are standard; you just assumed the wrong standard. The standard is pin size......7/8" on the lift arm pins and 3/4" on the top link pins. There is a generally accepted lift arm spread of around 22"-30".....or thereabouts, as it is an informally accepted standard, not an industry standard.
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
2022 BMW SUV (A53424)
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2015 INTERNATIONAL DURASTAR 4400 WATER TRUCK (A53843)
2015 INTERNATIONAL...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
7033 (A51691)
7033 (A51691)
