3 Point lift Bogging Engine YM2000
   / 3 Point lift Bogging Engine YM2000 #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
I know y'all must be getting tired of my questions.
I swear I'm getting close to debugging this tractor so please bear with me...
When I lift the 3 pt hitch to maximum height it drags down the engine. It does just fine as long as I stop the lift an inch before it reaches maximum height.
Am I missing some type of limiter or is there some way to adjust the lift..??
Lift is strong and works well otherwise.
td
   / 3 Point lift Bogging Engine YM2000 #3
Your straining the engine and bumping against the releif and it's letting off pressure to not dead head the pump. Your lift arms or top link are hitting tractor or you piston has topped out. You need to either not pull back all the way or adjust the linkage to not allow it to go that far up.
But it basically is working normal
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
2016 Ford Transit 350 Cargo Van (A50323)
2016 Ford Transit...
2852 (A51691)
2852 (A51691)
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
