3 Point Lift problem...still
   / 3 Point Lift problem...still #1
grafpatrick
Bronze Member
Sanibel, FL
YM2200
Hello all-
I am paying for not doing my homework and buying a VN orphan YM2200. Persistent problem with 3 pt lift being weak (wont fully lift my 5' brush hog) when oil is hot. Seems better when cold. FEL seems to be OK, I cannot tell a difference when hot or cold. Have completely changed oil, cleaned screen, replaced internal hydraulic ram with a tested used unit, then got the seals in it replaced (2 1/2 months) figuring the test was done with cold oil. No improvement. Implement will stay up when engine is shut down, suggesting no internal leaking. Lever linkage seems to be OK. Knobs under seat are properly adjusted. Used to work fine, so I assume FEL is plumbed appropriately.
Now what? I am wondering if it is the hydraulic pump, maybe just not putting out enough pressure and my 3 pt lift needs more than the FEL? Any way of testing it short of buying a new one? Any other parts or areas I ought to check?
John Churchill
Hello all-
John Churchill
   / 3 Point Lift problem...still #3
</font><font color="blue" class="small">( Persistent problem with 3 pt lift being weak )</font>
</font><font color="blue" class="small">( Used to work fine )</font>
Somwhere between those two points something changed. Did something happen to the unit that you know of? Anything? Any service, or changes of any kind?
If it weren't for "used to work fine" I would suggest incorrect fluid.
   / 3 Point Lift problem...still #4
I put all new JD 303 hydraulic fluid in it. The thing seemed to be fine when I bought it, then a year later started getting bad after a friend used it to pull some stumps. Do not know exactly what he might have done to it. It then gradually weakened to where it would not work at all, so I am actually better now than before, but still not at full capacity.
John
John
   / 3 Point Lift problem...still #7
I've only seen a couple dozen of these but it seems there is a (pressure) adjustment when you have the (3pt)valve body off. It has to be in that vincinity since the loader it working.
   / 3 Point Lift problem...still #8
2014 INTERNATIONAL MA025 BOX TRUCK (A53426)
2014 INTERNATIONAL...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
Enclosed Cargo Trailer (A51694)
Enclosed Cargo...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
