3 point mowers. Finish vs Rotary cutters
   / 3 point mowers. Finish vs Rotary cutters #1
acktractor
m5400 kubota
I am looking to mow fields of grass 6 to 12" in height. I have been using a Kubota zd331 with good results. I have allot of love grass which is hard to mow. I am looking at the ds96 woods or a prd 8400 woods . any thoughts
   / 3 point mowers. Finish vs Rotary cutters #2
i would go with a rotary cutter for that application.
   / 3 point mowers. Finish vs Rotary cutters #3
A flail mower is designed for rougher applications than a finish mower an gives you a much nicer finish cut than a rotary cutter. Have you looked into those?
   / 3 point mowers. Finish vs Rotary cutters #4
hp per foot though.. hard to beat a plain jane rotary cutter. flails eat hp.. and have a higher maint cost / time with the knives.. etc..
the only people around here that even try to use flail mowers are the county.. and that's because they are spending our money.. not their own money.
not a single one of the commercial mower outfits around here mows with anything but a rotary mower.. or grub mower for the land clearing stuff.. etc..
   / 3 point mowers. Finish vs Rotary cutters #5
Agree 100%. I do custom mowing also and use a rotary mower. Finish mowers were not made to cut like you are wanting to do, mainly yards and manicured fields.
   / 3 point mowers. Finish vs Rotary cutters #6
no question id go with the 3pt shredder.
   / 3 point mowers. Finish vs Rotary cutters #7
Flail mowers don't eject & throw stuff at high velocity like rotary mowers do, and they impact hard objects with minimal damage so they hold up better. When I was a kid all the municipal mowers used sickle bars to cut roadside ditches, now they use flails because they don't break as often and don't throw stuff through car windshields. But they are very slow going and do not leave a fine finish cut.
   / 3 point mowers. Finish vs Rotary cutters #8
our county still has a couple older flails.. but hasn't bought a new one in at least a decade.. same goes for the cities too.
too easy to go with rotarry cutters, rubber or chain guards, where applicable / specified.. and 1mil insurance.. :)
I don't recall reading about a municipal mower ever damaging a passanger car.. and I read the paper pretty much every day.. :)
simply way cheaper to run a rotary...
   / 3 point mowers. Finish vs Rotary cutters #9
I see counties using a mixed bag of rotary and flail cutters in my neck of the woods, although rotaries seem to predominate.
It has been a few years, but I recall reading about a Myrtle Beach (SC) motorist who was killed when struck by flying debris from roadside mowing by the county (or city?). I still cringe when I pass roadside mowers.:)
Steve
   / 3 point mowers. Finish vs Rotary cutters #10
Finish mower would work better at the small end of your range. (in the 6" stuff), and leave a better finish.
But if finish isnt a huge concern, and time is, you cannot beat a rotary cutter. In 10-12" stuff, it will easily be 2x's faster than a flail or finish mower.
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2008 FORD F-650 (A50854)
2008 FORD F-650...
2004 KENWORTH BUCKET TRUCK (A50854)
2004 KENWORTH...
