3 pt Log Splitters - What do you think? How do you connect and control the hydraulic
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #1
legeste
Fortville, IN
Ford 841
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #2
I have a Ramsplitter that I am happy with for my uses. I connect mine to the loader ports.
I have the 12T version with the 3.5" cylinder. It is sized better for my tractor. I run the tractor ~1900RPMS, and can split everything I want to. My wood is mostly maple, cherry, white oak, various others. The average round is 18" diameter. It is fast enough for me working by myself.
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #3
I think that for any regular use (over 3-4 cord a year) get a gas powered unit and save the wear and tear on your tractor. Think about it, a good log splitter pump AND motor is under $800 to replace!
Use your tractor to haul your wood to the splitter and then to the wood pile.
This way when your pesky neighbor asks to borrow the splitter, you won't have to give up your tractor:laughing:
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #4
You can find some lengthy threads on 3 pt vs. stand alone. We've pretty much beat that horse to death. The splitter will have it's own valve so you need an open hydraulic circuit. You can do this with a loader valve held open as many do, but an accessory outlet (power beyond) is the most functional way to do it.
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #5
If your tractor does not have enough GPM for a good cycle time, then a standalone splitter is the better choice.
A 11 to 28 GPM 2 stage pump will provide a good cycle time.
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #6
I see you list a ford 841 in your profile. Is this the tractor you are wanting to put the splitter on??
If so, I would advise against it. IT has a really slow and really weak 4gpm/2000psi pump on it. Not to mention it isnt really economical to run a 62hp engine to power a very slow splitter when a 6-10hp little motor will give much more power splitting, and much faster cycle times.
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #7
Only way I could consider a 3ph unit for your tractor is if it has a PTO powered pump. But then, those are just as expensive (if not more) than a stand alone unit.
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #8
I have never owned a PTO powered log splitter. A friend and neighbor of mine gave his PTO log splitter to one of his Son-in-Laws and bought a gas operated one. He really enjoys the convenience because this method allows him to use his tractor for other purposes. Just a thought. Best wishes.
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #9
Welcome to TBN :)
I moved your thread to the Attachments forum.
   / 3 pt Log Splitters - What do you think? How do you connect and control the hydraulic #10
Run my ford 4000 D at about 1000 rpm with a prince pto pump and reservoir - American 4 way splitter - excellent
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
2009 NISSAN Murano AWD SUV (A53424)
2009 NISSAN Murano...
New/Unused CFG Industrial MX12RX Mini Excavator (A54865)
New/Unused CFG...
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55302)
2021 John Deere...
