3 pt rototiller---fwd or rev rotation
   / 3 pt rototiller---fwd or rev rotation #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
I now have a Befco 60" fwd rotation rototiller.Possibly looking to upgrade to a 72 " rev rotation. What are the pros and cons of each ? Thanks
   / 3 pt rototiller---fwd or rev rotation #3
Not just rocks but anything in the ground, like roots, pipes, old wires, etc., that can cause a problem is better with a forward tiller.
Well it would only be used on plowed soil.From seeing mine trying to rototill virgin soil,it takes a beating which is why I will always plow first.
   / 3 pt rototiller---fwd or rev rotation #5
FWD uses less HP than Reverse as reverse is fighting against the tractor where fwd is pushing it.
   / 3 pt rototiller---fwd or rev rotation #6
While I own a Woods reverse-rotation tiller, here's a good video from Land Pride (another excellent, American-made product) that compares forward to reverse at around the 2:00 mark: https://www.youtube.com/watch?v=aWokqqt3wbw
For soils without a lot of rocks, reverse-rotation provides an excellent seedbed in my experience.
   / 3 pt rototiller---fwd or rev rotation #7
I am from upstate NY,I have a little dirt between the rocks!Don't know your particular situation but I can only use a forward tiller.
   / 3 pt rototiller---fwd or rev rotation #8
I have a forward rotating tiller because of the rocks and even in virgin soil, it does a good job if you go slow. I put my tractor in creeper gear and Low 3 or 4 and it is really slow, maybe 1/4 MPH but the tiller will make a good seed bed in a single pass. I can go in L 1 without the creeper gear and it is much faster but I have to make at least 2-3 passed to get the ground tilled deep and finely chop the grass.
So while a reverse rotation might go deeper with one pass, my forward rotating tiller will go to the max in one pass if no rocks are encountered even in virgin pasture that has not been tilled ever.
   / 3 pt rototiller---fwd or rev rotation #9
In my opinion, a reverse rotation tiller is just trying to make up for poor tiller design in the first place... ALSO, there IS a learning curve to getting good tilth, just putting the tiller on and beating the soil to death (going too slow) is never a good choice...
I never plow before tilling, it's just not needed... a plough (if you prefer that spelling) really is a good was to make compaction, then you need a sub soiler ect... I prefer to do a proper job of tilling and nothing else is ever needed, also NOTHING incorporates green manure better than proper tilling and I add a LOT of green matter every year...
SR
   / 3 pt rototiller---fwd or rev rotation #10
A plow ( or plough) and a tiller will make the same hard pan if ran at the same depth over and over. I do prefer reverse tine, but all will have what they like to operate. I can't stress enough, vary the depth over the years. I tend to plow more, but usually try and go shallow, like 4-7" It can be hard to keep at 4". Although, I don't plow that much either. And don't own a tiller anymore.
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2011 FORD F-450 (A52472)
2011 FORD F-450...
Brand New 5 gallon buckets (A53117)
Brand New 5 gallon...
Peterbilt 377 Semi-Truck (A53473)
Peterbilt 377...
