30 gallon Fuel Caddy - Change fuel - Cleanout?
   / 30 gallon Fuel Caddy - Change fuel - Cleanout? #1
beltfed
Bronze Member
Northern VA
Bobcat CT235
I just picked up a 30 gallon fuel caddy off of Craigs list. It was used with gasoline and I want to use it to fuel up my Bobcat. I have drained out all of the gas and have the bottom drain hole open along with the refill opening. I plan on leaving them open a day to 'dry' out the insides.
Do I need to do anything else to 'clean it out' before I pour in Diesel and use it to fuel up my tractor?
   / 30 gallon Fuel Caddy - Change fuel - Cleanout? #2
IMHO, it looks good to me, the way you have done it..Ymight give it a lite rinse and shake with a little diesel and dump it in a jar for a look see?
   / 30 gallon Fuel Caddy - Change fuel - Cleanout? #3
Every so often there will be a news story about the state police going to ski areas and ticketing bus drivers because they are adding gas to their diesel because they bought fuel down "south" without anti-gel and now it's gelled up. My point is that a little gas is not going to hurt anything, if you let it evaporate then you'll be fine. The only thing I would look for is any dirt or debris inside the tank and remove it.
   / 30 gallon Fuel Caddy - Change fuel - Cleanout? #4
I agree with crazyal, make sure you get any trash or sediment out. A little gas isn't going to hurt anything.
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
