3000 Series Deck Gear box Lube
   / 3000 Series Deck Gear box Lube #1
KBEAT
Bronze Member
Iv'e got a 3000 series tractor and have both a 44" and a 54" deck I picked up this winter. I reconditioned the 54" deck over the winter and was going to check the lube in the gearbox but I can't find any information in either the owners or service manuals. Just to add to my confusion when I look at both gearboxes the 44" has the plug at the bottom of the housing and the 54" has the plug at the top. I'm guessing the 54" was put together wrong because that looks like it would be too much oil in the housing. I assume it's just a fill till the oil comes out of the plug, but just wondering what yours looks like (Plug on the bottom or top of the housing) and what lube you have used.
   / 3000 Series Deck Gear box Lube #2
Usually there is a plug on the side which you remove. Then fill till it runs out. I use Mobil 1 75W90 in my Kubota mmm gearbox.
Thats the same lube I use on the gearbox for my Woods 3pt mower, so I have it on hand, but on the 54" deck the fill point is almost to the top of the housing. Seems if I fill it to there its just going to foam up while my 44" deck with the same gearbox has the fill point at the bottom. One has to be wrong.
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
JOHN DEERE CP690 LOT NUMBER 73 (A53084)
JOHN DEERE CP690...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
