3000 service info
   / 3000 service info #1
fowllife
Bronze Member
Northern Ohio
I want to change the fluids in my '73 3000 8 speed gasser, but I apparently packed my manual in preparation for the move that never happened and now I can find it. Can anyone point me in the right direction in terms of fluid type/quantity for the tranny and rear end? And also filter/screen locations? Will the newer all purpose fluid work or do I need OEM fluids?......I need to find that dang book.....Thanks in advance
   / 3000 service info #2
generic utf as sold at tractor supply and walmart is more than find.( TSC likely cheaper.. and both a warren oil )..
trans is a sump.. and rear end / hyds is a sump
engine oil filter if a spinon is a ph8a fram, motorcraft fli1, napa 1452.. etc. supertech st8a
if a cartridge filter element it's a ch14pl
don't have the quantities on hand.. but figure on getting a 5g pail of utf.
unless you are going to do surgery.. don't worry about the 3pt hyds filter.
if it has ps, there is a filter element there..
soundguy
   / 3000 service info
Thanks Soundguy. I assumed that utf would be fine. I thought that some of the old Ford needed something different, but I doubted mine was that old......I noticed some water in the tranny fliud when I checked it the other day, so that's the main thing that I need to switch out. I figured I might as well do the rear end while I was at it though.
   / 3000 service info #4
the ford n series originally used a 90wt mineral gear oil similar to a gl1 ( or 3 ) in the common sump.. but that too can be changed to utf if everything is in good working order. ( or ig not in good order.. r&r of the pump and lift cover is about an 8hr job start to finish, and not mor ethan a few hundred bucks as long as it is only cyl, piston, relief and gaskets and some pump parts, not the entire pump or pump and pto shaft.. etc. )
soundguy
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2017 TOP HAT TRAILER 16 FOOT UTILITY TRAILER (A53843)
2017 TOP HAT...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
