3010 Fan Belt Change
   / 3010 Fan Belt Change #1
Luray Farmer
How do you change the fan belt on a JD 3010? Oddly enough, neither the operating manual nor the shop manual offer any advice. It's not obvious how you get the belt off the lower pulley.
Bill Shields
Luray, VA
   / 3010 Fan Belt Change #2
Getting the old one off is easy. Use side cutters. Putting the new one on is a little more difficult. I haven't done one in about 10 years but I believe there is a coupler that connects the engine crankshaft to the hydraulic pump. I believe there are 1-2 bolts that hold it together that can be accessed from under the tractor or possibly through one of the front screens. That coupler needs to be removed to slide the new belt onto the crankshaft pulley. put the belt around the water pump and generator, tension it, reinstall the coupler and you are done. I don't remember them being too hard to do.
Informational Lot - Financing (A55218)
Informational Lot...
2020 GENIE TZ-34/20 ELECTRIC PORTABLE SCISSOR LIFT (A52705)
2020 GENIE...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
