3020 racing out of control
   / 3020 racing out of control #1
Billy Bee
Lowell Michigan
New Holland TC 33, John Deere 3020
I searched the JD 3020 threads and haven't seen a similar problem. The problem started with after running for a while the engine would start gaining rpm without moving the throttle, I would get off the tractor and turn the shaft that is sticking out of the carb with pliers, that would take care of the problem for a time but it would do it again within an hour. I assume the shaft controls the butterfly, it is a Zenith carb. That was then and this is now. Now I turn the shaft back and it wont stay and the engine races like crazy. I hooked a spring to it so as to not allow it to move on its own. This allows me to use the tractor but I think it makes it so the governor can't kick in as it will bog down easily when doing heavier work. Is it in the carb, the governor, or both? Throttle linkage is fine, both hand and foot throttles work fine.
Thanks, Bill
   / 3020 racing out of control #2
I would get in the carb and make sure the throttle plate is still firmly screwed to the shaft.
Thanks, Ruff I'll check it if-when the weather warms up. I'm pretty sure it is tight as I had it apart before. It seems like the shaft moves- rotates too easily, I can rotate it with my fingers. Isn't there supposed to be resistance?
TX
   / 3020 racing out of control #4
I'd suspect the governor. Might take it off and go through it for any disconnected or broken parts.
Cat Mixer RM-250C (A55973)
Cat Mixer RM-250C...
2019 Ford F-550 Altec AT41S 40ft. Bucket Truck (A55973)
2019 Ford F-550...
2019 Chevrolet Tahoe (A55973)
2019 Chevrolet...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
