3038H PTO shaft freewheeling
   / 3038H PTO shaft freewheeling #1
Tarnold
Ellijay ga
Ls 3038h, ford 1900
Is there a way to get the PTO shaft to freely move when hooking up. Having a hard time lining up the splines. Having to use a crow bar in the yoke to turn the blades on the cutter to try to line up is hard on everything, especially me.
   / 3038H PTO shaft freewheeling #2
No if I am not mistaken the newer tractors have a brake on the PTO to prevent freewheeling!
   / 3038H PTO shaft freewheeling #3
No, the brake prevents this. The easy solution is to make an adapter out of a PTO shaft extension, and a cheap wrench, or length of steel pipe. Then you slip the extension over the PTO shaft, and turn with the length of pipe...won't be a problem overcoming the brake.
   / 3038H PTO shaft freewheeling #4
try cutting the tractor off, some models will free wheel then
   / 3038H PTO shaft freewheeling #5
My R4047 stayed locked up whether the engine was running or not...think the G series is the same. It seems to be the norm with most machines now, although some tractors are starting to show up with a way to override the brake.
   / 3038H PTO shaft freewheeling #6
My J series rear PTO will freewheel when I select the mid-PTO.
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
Ford Stakebody Truck (A52377)
Ford Stakebody...
2014 Chevrolet Tahoe (A52377)
2014 Chevrolet...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
