318 vs. x500 vs. 265 or similar
   / 318 vs. x500 vs. 265 or similar #1
johndeereg
MD
Cub Cadet 107
I've been looking into getting a bigger, stronger tractor that I could use to plow snow, and haul our 15 cu.ft cart with firewood, and possibly mow. Also, I am getting addicted to John Deere lawn and garden tractors haha. I have a 175 Hydro I bought along the road for 600.00 which is a good tractor, and mows very nice. I'm not sure how much it is built for hauling wood around though. It also has very small tires for plowing snow. I bought my Dad an x320 and that is a nice tractor as well.
Now I am looking to buy something for myself that is heavier duty for push/pulling than the 175 Hydro I have. I've been looking into either an older tractor like a 318, or a 265, or maybe even a new one like an x500. I could use the 175 for lawn, or I could just use one tractor and sell that. What's your opinion on the best route to go?
   / 318 vs. x500 vs. 265 or similar #2
The front axles of the X530 and up are 1 inch diameter. X500 and X520 have 3/4 inch diameter axles. If load is an issue. X500 has lawn tires stock and X530 and up have more aggressive HDAP tires.
   / 318 vs. x500 vs. 265 or similar #3
I don't know that you can compare a 318 to an X500. I have a 318 and a 2305. I looked at replacing the 318 with an X series and just looking from behind there does not seem to be a comparison with the X500. I think you need to get into the X700 before you get something 318 weight and size. I have done a great deal of plowing with a 318 and it works well. It also mows nicely but I am not as picky as many. It really depends on what you are doing with it. For hauling a cart and mowing the 318 is overkill. Plowing it is marginal with deep N.E. snow but it can do the job.
   / 318 vs. x500 vs. 265 or similar #4
Don't sell the 175 Hydro short. I bought mine new 25 years ago and it is still going strong as my primary mowing machine. Our property is very hilly. I have also used the tractor to pull heavy loads its entire life. For years I routinely pulled a 500 lb flat trailer as a yard trailer. Can't imagine how heavy it was once loaded with limbs. For the past 5-6 years it's been pulling a JD 17P cart loaded sometimes to the max. I also pull a 900 lb lawn roller. Granted, traction can be an issue as without a diff lock it wants to spin the left-rear tire. But once it hooks up it has no problems pulling it. And... as per the owners manual... the hydro fluid has never been changed and has never used a single drop.
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
SET OF (4) 24.5 ALUMINUM RIMS (A53843)
SET OF (4) 24.5...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
