seal oil
With the tractor parked in my shed I noticed a spot of oil on the floor . The tractor is leaking hydraulic oil . Not a big leak , just a few drops now and then and is leaking from the transmission I think it is called . The area on the left side above where the filter pipe goes into the transmission is wet . It is also leaking on the right side of the transmission but not as much . Both sides are wet and is not leaking enough to tell where it is comming from . Is there a place where I can get a service manual or a parts diagram of the area leaking ?
