35 hp 4wd or 50 hp 2wd
   / 35 hp 4wd or 50 hp 2wd #1
stickbowman
Whitesburg, GA
Kubota
So i'm looking at used tractor with FEL. Seems for about the same money I can get a 4wd 35hp or a 2wd 50 hp. Mainly going to be working food plots, cutting, drive way scraping , moving dirt etc. Just general small farm activities. Any thoughts on which direction I should go?
   / 35 hp 4wd or 50 hp 2wd #3
Easy question. 4wd hands down. Most tractors are traction limited, NOT power limited. I've owned both. 2wd will get stuck in wet grass.
   / 35 hp 4wd or 50 hp 2wd #4
Tractors only have brakes on the rear wheels.
If you have hills, you only have braking on hills with 4-WD engaged, when tractor weight shifts forward.
2-WD tractors are prone to uncontrolled descents.
   / 35 hp 4wd or 50 hp 2wd #5
Absolutely get the 4WD
The front end loader will be MUCH less useful if you only have 2WD.
   / 35 hp 4wd or 50 hp 2wd #6
   / 35 hp 4wd or 50 hp 2wd #7
2-WD tractors are prone to uncontrolled descents on hills.
SOME tractors DO have brakes on the front wheels...
Although I haven't seen a tinker toy tractor with brakes on the front wheels.
SR
   / 35 hp 4wd or 50 hp 2wd #8
Will the 35 hp model with loader pull /lift what you need?
   / 35 hp 4wd or 50 hp 2wd #9
Get the 4WD - for sure.
   / 35 hp 4wd or 50 hp 2wd #10
No question, 4WD.
2014 KENWORTH T800 KILL TRUCK (A53843)
2014 KENWORTH T800...
2005 Dodge RAM 1500 (A50123)
2005 Dodge RAM...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A53426)
2010 PETERBILT 387...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A53843)
2019 TY-CROP...
