3500 rear axle seal replacement
   / 3500 rear axle seal replacement #1
Treebob38
Sanford Michigan
ford 3550
Has anyone done axle seals on a 3500 backhoe? Looking for advice mine are shot!
Thanks!
   / 3500 rear axle seal replacement #2
Before you do anything drastic, elevate the rear using stabilizers and bucket/boom and see if the bolts holding the axle flange to the hub are loose. Mine on both a 9N and my 3500 get loose and let trans oil escape, making me think that the seals are gone. Re-tighten them, and the leak goes away. After using the tractor for a while, they can get surprisingly loose.
Thanks, but all the oil is inside the drums.pulled the axles the bolts were very tight.got the new seals. The inner seals looked good but had hardened from age. I suspect the same for the outer seals. Working on a axle nut wrench now. Should have everything done this weekend sometime. Will take some pics and post.
Thanks for the response it is always helpful!
Bp
2014 DRAGON PRODUCTS STEPDECK 46 DOVETAIL W/RAMPS (A53843)
2014 DRAGON...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2024 New Holland T8.410 MFWD Tractor (A53473)
2024 New Holland...
