3510i Hydraulics and 3 Pt Hitch Questions
   / 3510i Hydraulics and 3 Pt Hitch Questions #1
Canuck_49
Tallahassee, FL
Branson 3510i
Hi - I don't know a lot about tractor hydraulics so please excuse a few dumb questions...... :confused:
Can rear hydraulics be added to a 3510i? Mine has a FEL and of course a 3pt hitch but I've started to think about uses for rear hydraulics. Is this an expensive add-on?
Are extra hydraulics needed to use a grapple on the FEL instead of the bucket? Is this an expensive add-on as well?
The 3pt hitch arms raise and lower fully with only a short movement of the control lever. Is there a way to adjust this so the full range of the control lever is used, not just the top 3 or 4 inches? Wouldn't that give me better depth control on my scraper blade for example?
   / 3510i Hydraulics and 3 Pt Hitch Questions #2
No dumb questions allowed! :D
Rear hydraulics can be added. Expensive? Depends on what you think expensive is. To add a set of ports on the rear would probably cost $200 - $300 depending on your valve selection, and what other hardware like pipes and fittings that you'd need.
A grapple can be plumbed to use a dedicated hydraulic circuit for its operation. Some people opt to add an electrically controlled valve mounted on the loader to toggle between having the FEL joystick control the bucket curl function and grapple functions.
Not sure on this one. For your other questions, I'm sure you'll find a lot of answers to your questions in the Hydraulics forum. http://www.tractorbynet.com/forums/hydraulics/
MicroPilot - thanks for the reply. Very helpful information and is much appreciated.
$200-$300 for rear hydraulics is not bad at all. I was thinking it might be in the $800-$1,000 range.
I'll check out both options for operating the grapple and the link to the hydraulic forum.
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
