3520 cab frozen door latch
   / 3520 cab frozen door latch #1
yooper68
UP Michigan
JD 3520 Cab
Wondering if anyone else has had ice problem with their door latch on 3520 cab? I leave the tractor outside in the winter, so there is almost always snow on the roof. As I am running it to plow snow, the snow melts and drips right onto the latch (much of it right near the "button") and freezes. It dropped below 10 degrees F last week and froze up so bad I'm having to use the "emergency" door (for some reason doesn't have as much problem). I'm thinking of making a little "gutter" to divert the drips or a rubber protector over the outer door latch/handle. Anyone with ideas? Thanks
   / 3520 cab frozen door latch #2
Spray it with Fluid Film to keep the water out?
   / 3520 cab frozen door latch #3
The window latches on the camper shell on my pickup were always doing that - freezing in place and darn near impossible to open.
One day I was looking for some new LED lights for my trailer at a Camper/Trailer supply house and they had those rubber boots that cover the handles.
That was the ticket!
AKfish
   / 3520 cab frozen door latch #4
Mine sleeps outside in a "tarp garage"...I've never had the problem you describe, but every fall I make a habit of wiping down all the door gaskets and such with pure silicone spray...
I do the same on my vehicles....
   / 3520 cab frozen door latch #5
Hmmm, thanks I did not think of doing that.
thanks for the help, fellows. I will dry it out with hair dryer, then spray everything down. Will also look for the boots that AKfish mentioned. I think that is really what I need. I'm trying to determine is something is wrong with the latch, as it works just fine from the inside; just can't get in by pushing the button from the outside. Will keep going in the other door until I get it figured out - just hope that button don't freeze up or I'll have to climb through the back window :(
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2005 Turtle Mountain 1 Ton Military Portable Power Unit Frame Trailer (A55758)
2005 Turtle...
Welder and Hammers (A47477)
Welder and Hammers...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2004 Freightliner FL70 Trash Truck, VIN # 1FVABTCS64HM47795 (A54865)
2004 Freightliner...
