3525 mahindra tractor..smoking under load
   / 3525 mahindra tractor..smoking under load #1
seedman4
I have a 3525 tractor that i bought new.i have changed the engine oil and tranny oil.the tractor has only 113 hours used time.i bought the tractor 1 and a half years ago..it smokes under a load when i use my backhoe.what could be the problem??
   / 3525 mahindra tractor..smoking under load #2
All diesels smoke a little when loaded, especially when a change in load occurs. this would be more so if you are operating the backhoe at low rpms.
If its continually belching smoke from the exhaust, white or blue being really bad, then there is a problem.
i am running around 1500 rpm.no white or blue smoke.just blackish color..
   / 3525 mahindra tractor..smoking under load #4
Does it only do it when using the backhoe?
yes mostly using the backhoe
   / 3525 mahindra tractor..smoking under load #6
could you give us some more info on the backhoe.......does it have a PTO driven hyd. pump?
have you tried to really put a load on the FEL to see if it smokes then?
have you tried increasing the RPM's to see if it continues to smoke?
   / 3525 mahindra tractor..smoking under load #7
The black smoke is probably a good thing and is most likely just unburned diesel fuel. It would be better, in my opinion (two diesels) than would white or blue smoke. My initial guess would be injector pump timing is off a bit. I have seen it on a 5500 Mahindra not too long ago....a little adjustment from a proper mechanic and it was good as new. Good luck and listen to the dealers in this situation. They have the experience with most situations.
Yes it is pto driven.
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
2011 Ford F-350 XL (A50120)
2011 Ford F-350 XL...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
