3550 hst problems,cheap built,lemon?
   / 3550 hst problems,cheap built,lemon? #91
We got the HST transmission because the super easy driving. Don't regret it at all and doesnt seem to rob power. Using the bucket is 20 times easier with the HST. I thought I wanted shuttle shift, which is good, but the hst makes a lot of other things easier. On level ground (safety people are going to laugh) you can be off of your tractor and use your hand on the pedals to inch up to that 1000 pound cutter. It was super convenient when drilling holes to operate the drill standing on the ground. I lightly set the parking brake so I could position the auger to start. When the auger gets in the ground, you can inch backwards to keep it straight. For brush hogging HST is just plain better because of the speed control and the back and forth near woods. I hope this helps.
I also have a 3550hst - and the hydro works very well for my tasks. For loader work, precise material handling, and ease of operation it's the way to go. It does lose some power due to the transmission, but the only time I notice that is when driving in high range - which isn't very often for me. Another advantage of HST for me is that lots of people run my tractor - and it's really easy to operate. I'd be much more nervous letting someone on the seat for a PST. The tractor has enough power to run a 6 foot bushhog in 2-3' grass uphill, as fast as I can drive in medium range. I sometimes wish it had 5 ranges - especially one between medium and high range. If you are doing hay work, lots of mowing, road travel, and not lots of loader work, the power shuttle might be a better choice.
   / 3550 hst problems,cheap built,lemon? #92
it works great to mount/dismount my backhoe, like that. I haven't taken off the fel, but I'm sure I'd do it that way too.
I see no downside to an hst.
   / 3550 hst problems,cheap built,lemon? #93
I can see right now that a gear tractor is waiting in **** and it has your name on it. LOL And it might even be a Deere or worse.
   / 3550 hst problems,cheap built,lemon? #94
I doubt it. The gear was not that much of a torture machine for me.
I had a gear tractor for almost 25 years and was happy with it, until I got the hst. I could use a gear fine, but the hst is just so much easier and versatile to use.
If all I have waiting for me in **** is a gear machine, I'll be happy.
   / 3550 hst problems,cheap built,lemon? #95
That got me thinking... there's a gear tractor in **** waiting for me with several hundred 3pt implements resting on uneven ground that I have to move to the other side of **** every day.
   / 3550 hst problems,cheap built,lemon? #96
And I don't know if it has turfs, or R4's, either.
   / 3550 hst problems,cheap built,lemon? #97
Cheat. If all you have to do is move them, just move them with the loader and some chain if necessary. There are no rules in **** ya know.
   / 3550 hst problems,cheap built,lemon? #99
The shaft must be the designed weak link. It is not hardened or it wasn't hardened since it was broached. The direction of the twist was in the reverse direction; which means it sheared with forces in the reverse. I was expecting the opposite, like taking to much torsion going into a gravel pile or ramming something.
The splines did not shatter as a hardened piece would, but rather they twisted right along with the core metal. An engineer would have probably deliberatly made this piece weaker since it is the cheapest piece to replace. the only time I could imagine the front wheels took extra force was getting gravel from a creek and punching it in reverse as I coming fast at a hidden root ball (I hit it anyway).
   / 3550 hst problems,cheap built,lemon? #100
Just some hydro advice. Everything I have is hydrostatic. Your tractor should handle seven foot cutter too.
Grass requires some sharpness, but brush goes down easy with the 3550. Please blow off the entire radiator area each time you use it. The egr cooler adds another coil and it really needs it. Always let her cool down at idle before shutting her down. In addition, specific to the hydrostat: Don't let her groan. Keep rpms above 2000 (2500 for cutting) because the lower the rpms--the higher the angle of the swashplate. It is better to have higher rpms with less angle on the swashplate to reduce wear and fade. A hydrostat is a power-washer pump. Literally. Several small pistons arranged in a circle with an angled plate raking over the ends. The slower it turns, the more the pistons get slapped on the side and less on the top. The same amount of work gets done, just more wear on the little pistons and their bores. So, high range really is only for road travel.
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
FORD 545D TRACTOR (A60430)
FORD 545D TRACTOR...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
