3550 Shuttle Lever Very Stiff In Cold
   / 3550 Shuttle Lever Very Stiff In Cold #1
tbzep
Bronze Member
TN
1948 Farmall Cub, 1952 Ford 8N, 1962 Ford 861 (sold), 2015 Mahindra 3550, 2017 Gravely ZT HD 52
The shuttle lever has gotten almost impossible to move in near freezing temps and below. It stays in the dry so there is no ice and stiffens before hitting 32 anyway. Has anyone experienced this and happen to know where it is binding so that I can lube it with something that doesn't harden in the cold?
   / 3550 Shuttle Lever Very Stiff In Cold #2
I have a 2540 shuttle.. I notice that too around the 60 hours, and it was in the hot days we hardly get cold fronts in south tx.. I lube all the linkage down to the transmission same results. It was the one that was holding the shifter under the dash close to the steering column.. hope this helps
I'll dig in and take a look. Thanks.
Update: I haven't had time to work on the tractor, but the temperature was around 38-40 today and the shuttle lever worked just fine. It will give me trouble again next cold spell. Hopefully I can figure out where it is binding without having to work on it in freezing temps.
   / 3550 Shuttle Lever Very Stiff In Cold #5
I know nothing about the design of this. Do you know if this is actual mechanical linkage or a cable and housing? If it's cable and housing maybe some contamination has gotten inside? Just throwing darts at it....
   / 3550 Shuttle Lever Very Stiff In Cold #6
My 4035 does the same thing, both the 4035 and the 3550 share the same linkage. I have found that a shot of WD40 or PB blaster onto the ball that locks the lever in place will help keep it a little easier to move. I have read that you can get water in the cable for the shuttle cock. Once water is in there, it won't drain out, so, even when stored covered and dry, it is entirely possible that the line may be freezing.
If it is forecast to be below 28 or so, I will plug in the tractor for at least six hours while keeping the hood and dash covered with a duck tarp. I have found that the small amount of heat coming off the engine is enough to have the shuttle cock nice and free when I go to start it up.
Once it warms up this spring, I will completely fill the shuttle cock cable with pressurized grease to remove whatever water I have in there.
   / 3550 Shuttle Lever Very Stiff In Cold #7
Im thinking that the lever could be slightly bent, seen this happen before and its very possible
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
Honda UTV (A56859)
Honda UTV (A56859)
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
John Deere 7410 (A53317)
John Deere 7410...
