Oil & Fuel 3600 ford fuel tank rusty
   / 3600 ford fuel tank rusty #1
georgia plow boy
Bronze Member
I have a 3600 ford diesel and about every 6 or 7 hrs of use the pit cock, I guess it called that,its on the bottom of the tank where you cut the fuel on and off fills up with rust, I thought it was gunk as I haven't had the tractor long, but as much as Ive drained it and filtered the fuel Im thinking its rust now, My question is if I keep doing this will all the rust finally get gone or am I going to have to get a new replacement tank Ive seen some plastic ones on e-bay by the way or maybe take this one off and get it sandblasted and coated with somthing, Im very limited on money but I would like to get this problem fixed its mighty hot here to be stopping and working on my tractor every time I bush hog thank for the help
   / 3600 ford fuel tank rusty #2
Over the years, we have had good luck by removing the tank, putting some pea gravel in there, put the cap back on and shake it hard, remove rocks and rust, flush with diesel and repeat one more time. You can pick the marble sized Pea Gravel at most lawn and garden centers by the bag. Ken Sweet
   / 3600 ford fuel tank rusty #3
I seem to remember that there is a kit to coat the inside of gas tanks that people use on old cars that would most likely work.
Is it complicated to take the fuel tank off, Im not much of a mechanic, Should I try to find a manual, or get someone that knows how to do it, or is it somthing that is pretty self explanatory like just taking things off until it comes out btw thanks for your help
   / 3600 ford fuel tank rusty #5
Pretty straight forward mechanics, Just remove the sheetmetal and there she is. No manual needed for this type procedure.
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2002 International 9200i Truck (A53472)
2002 International...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2000 GENIE S-60 MANLIFT (A51246)
2000 GENIE S-60...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
