360dtc clutch problems
   / 360dtc clutch problems #1
Jesse Cornelson
Farmtrac 360dtc
I have a 360dtc that the clutch is acting up on. It will act right sometimes, but if you go to working the bucket for some reason it will get out of whack and the clutch won't disengage right.
Its wierd, if you run it without a load for a little while, the clutch will go to acting right again. As soon as you push some dirt around with the bucket or if you get a heavy load in the bucket and jiggle it a little to shake the loose dirt off it will make some hard metalic rattling sounds and then the clutch will go back to not disengaging again.
Any ideas?
I figured it out. 4 of the 6 bolts that holds the engine to the transmission were missing.
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
Toro (A56857)
Toro (A56857)
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
CAT 930M (A58214)
CAT 930M (A58214)
