3616 grease fitting above front axle
   / 3616 grease fitting above front axle #1
jim3616
upper valley, nh
mahindra 3616
I'm having a difficult time pushing grease through the fitting above the front axle. I pulled the fitting and it's fully machined. Anyone having this issue?
   / 3616 grease fitting above front axle #2
I haven't.
   / 3616 grease fitting above front axle #3
On the front axle pivot? Those can be under tremendous pressure and at times won't take grease from the $10 auto store grease guns, but require the heavy duty high pressure grease guns. Try using the loader to lift weight off the front axle and give it a squirt.
   / 3616 grease fitting above front axle #4
Same problem with my 3016 and I am using so much pressure from my air grease gun its pushing off my clip on grease gun fitting. I pulled mine all apart and found it had grease and for the life of me I can't see the path grease is suppose to take.
   / 3616 grease fitting above front axle #5
My dealer said its tight tolerances making it difficult to push grease in. They said It's taking grease just really slow.
I'm finally pushing a small amount of grease - very tight tolerance
   / 3616 grease fitting above front axle #7
As Sysop says, if you have a loader, put the bucket down and lift the wheels off the ground, this make it easier to get grease in. If you don't have a loader then a heavy impliment ie box blade, on the 3ph to transfer weight off the front axle will help getting grease into the axle pivot.
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
