38 Simplicity Mower deck Idler pulley ?
   / 38 Simplicity Mower deck Idler pulley ? #1
olmy
Simpliciy Legacy XL 2010
On my 38 Simplicity Mower deck I know the Idler pulley (part #1685150SM) should spin with the mower belt turning it. Does the center of that pulley have a bearing that should spin or is the center stiff and it spins on the bolt that goes through it. It keeps seizing up and I can not tell if that is a frozen piece or just to tight. This deck is on a Broadmoor 1998 or so. If the pulley is solid how loose should the bolt through it be. Thanks
   / 38 Simplicity Mower deck Idler pulley ? #2
All the idler pulleys I have seen have a bearing.
2018 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2018 CATERPILLAR...
(2) TRACTOR TIRES (A54757)
(2) TRACTOR TIRES...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
UNUSED 72" HYD ROCK GRAPPLE (A54757)
UNUSED 72" HYD...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
