3940 2008 with no 3pt hitch need help with parts
   / 3940 2008 with no 3pt hitch need help with parts #1
gusman2
STOW,MA
KUBOTA L3940HST BACKHOE
I just picked up a used 2008 kubota l3940 with a b90 back hoe. I have no 3pt hitch arms or top bar. I do have the lift mech and stuff but the lower arms and 2 stablilizers to the sides as well as the top bar was removed and there is no way to get it now. The dealer wants 2,000 for the bars any ideas. I may have access to a used 2005 one of a l3400 it has turnbuckles. and is 300 Should I get that or spend the extra 1700 Thanks mark going to use it for snowblower and box and scraper blade.
   / 3940 2008 with no 3pt hitch need help with parts #2
I would price at some other dealers to try and find lower cost. There is alot of markup on parts, try negotiating. If you have the part numbers, try google and ebay search. If it were me, I would stay with oem parts. Good luck. Philip.
   / 3940 2008 with no 3pt hitch need help with parts #3
Gusman2: I just checked out that same tractor set up from a dealer in NJ. I asked about the 3 point arms and bar and he did not have them. When the BH attachement is put on at the dealership the arms ans bars are taken off to install th BH and sometimes get lost in the shuffle. I never realized how expensive thet were. You mention that you need it for a snowblower so I guess you are looking for someting quickly. Personally I would check out the used option for 300 first as it will probally get the job done for you this winter and you can take it from there.
   / 3940 2008 with no 3pt hitch need help with parts #4
   / 3940 2008 with no 3pt hitch need help with parts #5
You may also want to check with Weaver's Compact Tractor Parts as they may have some used lift arms and/or other alternatives.
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2021 New Holland C327 Compact Track Loader (A53473)
2021 New Holland...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
Towable generator (A52377)
Towable generator...
