3PH control lever
   / 3PH control lever #1
jdrotert
NW of St. Louis, MO area
B2150DT
On my B2150D, when I raise an implement a short distance, say an inch or two off the ground, the 3PH control lever won't stay in place. It will drop down and the implement will drop! Is there some adjustment that will keep the control lever in place? The lever seems REALLY easy to move throughout the range. It's not loose on it's shaft. Any hints?
   / 3PH control lever #2
On my old L345, there were two nuts on the 3ph lever, the inner one adjusted the friction drag and the outer jam nut held the adjustment.
Cheerful refund if irrelevant !
   / 3PH control lever #3
Your tractor has a spring/cup washer set up. Tighten the nut and you apply more tension to the cup washers giving the control handle more friction. If tightnening the nut does'nt help, the washers are probably worn. Common problem. New washers and your in buisness, just remember to pay attention to the direction of the cups when dissassembling.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2008 John Deere 6330 Premium with Trebro Sod Harvester (A52128)
2008 John Deere...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2018 JLG SKYTRAK 6036 TELESCOPIC FORKLIFT (A51242)
2018 JLG SKYTRAK...
2008 CATERPILLAR 314CL CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2012 John Deere 7280R MFWD Tractor (A52128)
2012 John Deere...
