3pt hitch on John Deere 3038E
   / 3pt hitch on John Deere 3038E #1
deepockets
Crawley
JD 3038E
We have a JD 3038E we purchased new three years ago that has been operating fine until about 4 weeks ago when we the mower deck. We can adjust all the way up but if we park the lever anywhere but full up the hitch arms lower all the way down. Any one had this or similar problem? we checked fluid level and changed both hydrolic filters.
   / 3pt hitch on John Deere 3038E #2
on my 4105 there is an adjustment. I had to remove the lift arm from the bar that goes to the thrust block valve. Once I did that, there was a nut that can be tightened. There are 4 disc spring that keep the tension tight.
Go to the John Deere site
parts catalog
Model search, put in your model
pictorial index
2-3038e compact utility tractor
Hydraulics
rockshaft control valve
part #'s 10,11 and 12
Tighten on nut to tighten the tension on the disc springs
Let me know if this works
John Deere 10 Shank Chisel Plow (A50515)
John Deere 10...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
WATER CONTAINMENT/TRASH CONTAINMENT SKID (A50854)
WATER...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
