3Pt. Lift Arm Turnbuckles - Specs?
   / 3Pt. Lift Arm Turnbuckles - Specs? #1
toddwulf
Cameron Park, CA.
1998 New Holland 1920
Can anyone give me the specs on the 3 Pt. Lift Arm Turnbuckles that prevent the arm's from rubbing against the inside of the rear wheels for a NH 1920, 4x4? Specifically, I need the recommended Arm Length(s) and rod stock. From my stock gear, which I'm not certain is OEM as I bought the tractor used, the first arm is permanently welded to a U shaped piece of same diameter rod and therefore permanently attached to the through bolt which attaches to the lift arm. It's threaded on the other end to the turnbuckle and the reverse arm is identical except that it connects to a U bracket that is pinned for attaching to the axle point. I'm just wondering if I can pick this stuff up, or a similar or superior setup locally, as opposed to having to pay for OEM parts. Any alternative setup's, if a picture is available, that's worth much more than 1000 words to me! But I'll take all suggestions to save my tires! My original setup has one arm broken which caused the other to become pretzel (bent) like in it's appearance. Thoughts folks?
Todd in Placerville, a.k.a Hangtown, a.k.a Dry Diggins. Once the third largest city in the State of California.
   / 3Pt. Lift Arm Turnbuckles - Specs? #2
I have a 1997 NH 1920... I'll go outside this afternoon when I get off work, and I'll take some pictures of the oem setup, and post them.
I also know that tractor supply company has rear stabilizers.
Also... On my older tractor, i used chains from the rear axle connections, to the pin holes in the lower lift arms. This only works when there is an impliment attatched.. when one is not attached.. try connecting a bungie from lower lift arm to lower lift arm to supply tension to the chains. Also.. if you don't use pto attatchments, you can use that same chain setup slightly modified that neither lower arm will contact tires with or without an impliment, but will interfere with pto shafts.. ( X pattern plus the regular pattern ).
Look for the pictures late tonight or tomorrow morning, as I get off my night job around 11:30pm tonight.
Soundguy
""wondering if I can pick this stuff up, or a similar or superior setup locally, as opposed to having to pay for OEM parts. Any alternative setup's, if a picture is available, that's worth much more than 1000 words to me! But I'll take all suggestions to save my tires! My original setup has one arm broken which caused the other to become pretzel (bent) like in it's appearance. Thoughts folks?""
   / 3Pt. Lift Arm Turnbuckles - Specs? #3
Try this link for parts, if you can figure out what you need:
<A target="_blank" HREF=http://www.soonersales.com/6/cat6.htm?253>http://www.soonersales.com/6/cat6.htm?253</A>
Chuck
   / 3Pt. Lift Arm Turnbuckles - Specs? #4
check out efcconstruction.com for pics of Buck's 3 pt hitch setup
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2014 Ford F-550 Altec AT37G 37ft Bucket Truck (A50323)
2014 Ford F-550...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2016 Ford Escape SE AWD SUV (A50324)
2016 Ford Escape...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
