3pt lift on Ford 1510 tractor
   / 3pt lift on Ford 1510 tractor #1
Motis
Denison Tx.
Ford 1510
Need someone with knowledge of the hydraulics on a Ford 1510 with a front end loader. Can't get the 3pt to lift unless I disconnect the front loader. Have already replaced seal in 3pt lift and rebuilt joystick valve, have not done anything with manifold block, could this be the problem? Also what position should the screw on the manifold block be in? It says in the manual (lift linkage operation) and (hyd equipment operation) Does it need to be left in one position for both the front loader and 3pt lift or switched from one to the other? Any help would be appreciated.
   / 3pt lift on Ford 1510 tractor #2
Motis, I have a 1710 Ford, the screw on the manifold block should point towards the rear when the loader is mounted.
   / 3pt lift on Ford 1510 tractor #3
It sounds to me that your loader is missing it's power beyond valve, or the PB valve is broken.
However I don't know your tractor, so I could be wrong.
   / 3pt lift on Ford 1510 tractor #4
I have a 1510 and the loader & TPH cannot both work at the same time the screw is a ball valve. pointed toword the rear is for TPH, and toword the gront the loader.
WOODS DHS48N LOT NUMBER 75 (A53084)
WOODS DHS48N LOT...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
New/Unused 10ft Workbench with 30 Drawers (A51573)
New/Unused 10ft...
