3-Point Hitch 3pt will not raise
   / 3pt will not raise #1
Rounder66
Longview,tx
Farmtrac 360
I have a 360 that has had a backhoe mounted for some time, took backhoe off and now I can't get 3 pt to raise.
Fluid is full, turned both hydraulic flow control knobs both directions, still nothing. Front end loader works fine as did backhoe when mounted. Anybody have any knowledge of this problem?
   / 3pt will not raise #2
The hoses that were disconnected when the backhoe was removed need to be connected together on the tractor.
JerryG, thank you for the response. Attempted to connect hoses together but they are not set up to do so.
I did hook the hoses from backhoe to the tractor thinking that might do the same thing as connecting to each other, still no luck. The only thing I can come up with is to try and find a hose with two male quick connect ends or have one made. Is the need to connect the hydraulic ports something specific to the farmtrac do other tractors require this?
Thanks again
   / 3pt will not raise #4
How is the hook up from the Backhoe If it is to Aux ports in the back I do not think that is the issue. Do you have draft and position???? On my 555 I had a spring break in the linkage and there was no movement. Do not know if the 360 is similar.
   / 3pt will not raise #5
Hey bud I just picked up a 360 and am having the same problem was just wondering if u got it figured out and how?? New to tractors so any info would help thanks!!
   / 3pt will not raise #6
My 460 does the same thing from time to time.
Under the front of the seat, there is a big nut facing up. There is a piston in there that goes up and down. Undo the nut (it's under spring pressure, but it won't go flying). Take your pinky finger and stick it down in the piston and pull it out. Check it to see if there are any rough areas that need smoothing.
Sometimes just taking it out and putting it back in solves the problem for months.
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
