3rd function issue and fix.
   / 3rd function issue and fix. #1
RadarTech
Elite Member
North Carolina
2007 Kubota L3400, YANMAR YT359C
Hello!
Many times an issue will hit us and not always does someone find it, and fix it and post it.. so here is mine..
The factory 3rd function on the 359c wasn’t working with a new grapple.. so I wondered if it was a blocked hose, etc
After checking everything I could think of, I started tracing cables. And hoses.
On the factory kit it is an electrically actuated system.
So I turned the tractor off, set the ignition to accessories, and clicked the button. I should have heard the actuator.
I didn’t.. under the cab in a very specific area is a “relay”. As I was checking the wires, and tracing them, a connector popped loose. .. after significant effort. I got it back together and everything worked..
Tips—-
Put a tool kit on the tractor with the following.
9,10,11,12,13 mm open and boxed wrenches.
A small ratchet set with the same.
Some dilectric grease.
Regular pliars, medium and large channel locks.
Electric tape, a couple pair of disposable mechanic rubber gloves and a small roll of shop towels.
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
1995 Ford F-800 Water Truck (A50860)
1995 Ford F-800...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2005 International 8600 Hydro Vac Truck (A50860)
2005 International...
