4000 Ford Dash
   / 4000 Ford Dash #1
Down South
Long 360
Anybody had to deal with a Dash Instrument cluster mounting?
I have a 68 with a C5NN-10A949-B threaded inserts molded in.
All I have found is a C5NN-10A949-c ( 1965 up) with big holes, nothing to mount the gauges.
Reading the description is E6NN10N849AA 4 nuts that are not illustrated.
I looked at a 75 3000, no gasket but it had 4 sheet metal nuts, 3/4" or so wide.
I did some looking and found only 1 place online that listed them and most of there web site was inop.
Does anybody know where i can get such nuts?
DS
   / 4000 Ford Dash #2
those clip nuts are similar to body panel mounting nuts.. not much mor ethan bent tabbed thin metal to screw thru.
in a pinch i have taken tin tabs, trimmed oblong, bent then in half, used a nail and a block of wood to make a pilot hole, then slipped them ove rthe place I'm screwing to. done this on dashes and radiator grill mounts.. works fine...
soundguy
   / 4000 Ford Dash
That sounds better than trying to rig a t nut or finding a wide spring steel nut
Ds
   / 4000 Ford Dash #4
many of my tractors have them.. :)
   / 4000 Ford Dash #5
Up here those flat spring nuts (not sure of name) are a common hardware store item, in those cardboard divided boxes of nuts/bolts, etc. I would think the spring steel in them is more durable than sheet metal in a vibration situation. edit: clip-on nuts, McMaster Carr calls them: McMaster-Carr
Jim
   / 4000 Ford Dash #6
Most Auto Parts stores, O'Rileys, NAPA. Auto Zone, Advance, Pep Boy's, Western Auto carry them.
   / 4000 Ford Dash
Still haven't measured but these are 3/4 or wider and shallow with a #10 screw hole.
Most this wide will be deeper with a bigger screw or bolt hole.
What amazes me, the c was a up grade covering 65up yet the required nut isn't available?
DS
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
2017 Ford E-450 Passenger Bus (A56858)
2017 Ford E-450...
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
Giyi Mini 4-N-1 Bucket (A57149)
Giyi Mini 4-N-1...
